[Solved]Error codes, problem searching (Automizy action)
Status: Closed · Asked by Istvan on · 0 views
Istvan — Question ·
I get error from "Create or Update Contact with Custom Fields" Automizy action in PC.
code - 500
message - There was an error
Everything went well this morning. This afternoon, all such actions ran into same error.
1, Does the error code and message always come from the app, in this case from Automizy?
2, How can this error be investigated? Is there a list of possible error codes?
Pabbly — Reply ·
code - 500
We checked and looks like the API of Automizy was down for few seconds -
You can re-execute the workflow and it should workout for the task which comes with 500 error as shown below -
Sandeep Bhansali — Reply ·
how can i re-execute all tasks which have errors in one go.
