Split a long string
Status: Closed · Asked by elhanan cohen on · 0 views
Hi, I received data from webhook in XML.
I want to use it in pieces from data,
but iterator is not allowed to use in data.
maybe you know another tool that will allow me to forward only some of the data?
You can try Text Formatter by Pabbly: Split Text action as shown below:
Also, check Text Parser action event, it may be helpful.
