Split Text Formatter Doesn't Work Properly If Separator Not Found
Status: Closed · Asked by AutoSpot on · 0 views
Right now my separator for split text is a semicolon.
If there is no semicolon found, the split text function should still work and the output should be the same as the input.
For example, if the input is "split this regardless if semicolon is found", then the output should be "split this regardless if semicolon is found" as the first, second, all, etc. segment.
Right now by the way it's programmed, the action step is failing if the separator is not found.
Can you please have this fixed?
Hey @AutoSpot
Kindly provide us the workflow name or workflow URL in which you are getting the issue so we can check on it and guide you further.
