Squarespace + Stripe integration is Native or need Pabbly Connect
Status: Closed · Asked by Vitoto on · 0 views
Vitoto — Question ·
Hello, I would like to quote your services for a Squarespace + Stripe integration, only books will be sold by catalog.
We are not sure if something like pabbly connect, zapier, automatio.io, etc. will be required, we need to clarify that issue in order to forcefully quote the requirement.
Thank you.
Hey @Vitoto
Could you please elaborate on your content once, do you want to create a workflow with Squarespace and stripe?
Vitoto — Reply ·
This is my required, may you can analisis.
We what mount EComerce and need sell onda documents an little catalo, Stripe is necesary for pay ?
En resumen, we neeed TIME, PRICE and GARANTY.
Vitoto — Reply ·
This my required. need know times, prices, etc.
What technical info you request ?
Hey @Vitoto
Could you rephrase your concern again in your language so that way we can convert that and look over it, as we didn't understand your language?
Vitoto — Reply ·
Where can I find people to quote this development?
Pabbly13 — Reply ·
Hey @Vitoto !
Can you please write us your concern in your native language and post it here.
So we can translate it at our end and guide you further on it.
Hope, to hear from you soon.
Vitoto — Reply ·
Necesito un presupuesto para integrar un portal web www.aprendio.io con Squarespace + Stripe or el portal www.aprendio.io directo con Stripe.
Es necesario para esto Pabbly Connect ?
Pabbly13 — Reply ·
Hey @Vitoto !
Thanks for the details.
We do not have integration with Aprendio.io with us, so your use case is not possible to implement.
Kindly request for new application here https://pabbly.hellonext.co/b/Integration-Request and upvote it.
Our team will review the request and possibly add the integration soon if possible.
But, we do have integration with Stripe and Squarespace with us.
Here is a video tutorial for reference-
youtube.com/watch?v=wv4MOVRxzfU
We would suggest you create a workflow by making a free account in Pabbly https://accounts.pabbly.com/signup/ by taking the help from the above video tutorial and checking if it works for you or not.
A free account consists of 100 free ask which can be utilized till they get exhausted. If needed we can provide you with the additional tasks for testing.
Do let us know if you get stucked in any step, so we can check it for you.
Hope, this works for you.
