Streak Box ID
Status: Closed · Asked by mkopp129 on · 0 views
mkopp129 — Question ·
I was able to create a box and a contact, but I don't know how to add the contact to the box using the Box ID or Contact ID. I believe I'm supposed to use the Search Data but I'm not sure what goes into the query. Any help is appreciated.
PabblyMember4 — Reply ·
Hey @mkopp129
You can use add contact to the box endpoint in the StreakCRM. Screenshot for your response:-
mkopp129 — Reply ·
Yes I got that. But how do enter the BoxId? I tried the search data and looked for a box id field but couldn’t find anything except key and that didn’t work.
Hey @mkopp129
We are checking the details with the team. Kindly allow us a day's time to reply back with an update.
