Stripe to CJ dropshipping not receiving data
Status: Open · Asked by Novaxs on · 0 views
Novaxs — Question ·
I set up the web hook and stripe to send payment data to Padley but when I try to map the fields in the CJ dropshipping step probably says there are no Fields available I've tried recapturing the response several times and even added a new connection from scratch but it still doesn't work
Hi @Novaxs,
We’ve checked your workflow and found that no response has been received from Stripe, which is why you’re unable to map fields in the CJ Dropshipping step.
Field mapping only becomes available after a successful response is captured from the trigger step.
What we recommend:
  • Reconfigure the Stripe webhook and ensure it is correctly set up
  • Trigger a real test event (payment) to capture the response
  • Once the response is captured, the fields will appear for mapping in the next steps
You can follow this tutorial for proper setup and capturing the response:
youtube.com/watch v=-4A-dtoUYbM:212
We also recommend creating a new workflow and following the steps in the tutorial to avoid any configuration issues.
Once the Stripe response is captured, you should be able to proceed with mapping in CJ Dropshipping.
Let us know how it goes.
