Survey Monkey Problems
Status: Closed · Asked by drhanus on · 0 views
drhanus — Question ·
Was previously able to connect Survey Monkey to Pabbly but now cannot even connect the two in the first step of the multi-step process. Can someone help please?
Hi @drhanus,
drhanus — Reply ·
Hello....I've made a little progress but need help. I am able to connect the survey monkey with sheets but sheets keeps calling in the same information from the data fields even if I fill in the survey in differently. Could you please help? Where can I find the workflow URL please?
Based on your description, it seems that the issue was related to the Response ID not being mapped correctly in the second step. As a result, it remained constant, and you were getting the same responses recorded in your Google Sheets spreadsheet. It appears that you have made changes to your workflow, and it now seems to be working as intended.
This would be your Workflow URL.
