Swiftia CUSTOM WEBHOOK PROBLEM
Status: Open · Asked by Bananajuice2002 on · 0 views
Bananajuice2002 — Question ·
Hey guys,
I’m having an issue with a custom API request in Pabbly when trying to generate a short clip from a Cloudinary video URL using Swiftia.
Could you please double-check whether this is an issue with my Pabbly configuration or something on the Swiftia side (permissions / API access / endpoint usage)?
Webhook / Request setup:
https://connect.pabbly.com/workflow/mapping/IjU3NjcwNTZkMDYzZjA0MzA1MjY0NTUzYzUxMzIi_pc
Swiftia API documentation:
https://app.swiftia.io/docs
Hello @Bananajuice2002,
Upon checking the API request, it appears that the render POST request expects a job ID to be passed in the request body. Please refer to the attached image for a clearer understanding of this requirement.
We recommend reaching out to the Swiftia support team to confirm which sequence of API endpoints needs to be executed (for example, job creation followed by render) to achieve your desired use case.
Once you have clarity on the required endpoint flow, you can configure the same in Pabbly using the API module.
Let us know if you need any further assistance.
