Switch from "24hr" display time to "12hr" possible?
Status: Closed · Asked by Branden on · 0 views
Branden — Question ·
Is it possible to change the workflow display times in the "history section" from a 24 hour display to a 12 hr display? ("10pm" instead of "22:00").
Thanks!
Hi @Branden,
Currently, we don't have an option to change the time format from 24-hour to 12-hour. If you would like the time in Task History to be displayed in 12-hour format, you can submit your request on our dedicated platform: https://pabbly.featureos.app/b/Feature-Request
Our development team will review your request, and if feasible, add the desired feature to Pabbly Connect.
