systeme.io funnel leads automation process
Status: Closed · Asked by JSS Institute on · 0 views
Hello guys,
I have a doubt about the automation process. I'm going to run a webinar campaign and I've created a funnel using systeme.io what I'm planning to do is whenever the leads registered on my funnel, I need to send a message on their registered email and WhatsApp immediately after they sign up using wati for WhatsApp. so, how do I integrate my automation process? like what should be my trigger and action? the last question the leads collected on my funnel will automatically go through WhatsApp or should I put them separately?
Looking forward to your answers,
Thanks,
Jagadish
Hey @JSS Institute
For your concern use case, you can refer to the following screenshot.
Kindly try this at your end and let us know if that works for you.
