Tally Data Capture
Your Workflow URL
https://connect.pabbly.com/v2/app/workflow/mapping/IjU3NjYwNTY0MDYzMTA0MzE1MjZjNTUzNzUxM2Ei_pc
Consent to Access & Modify
I authorize Pabbly Support to log in to my account and make changes to the specified workflow for troubleshooting.
I'm using Tally to capture new responses using the same form, but for some reason if I use New (beta) the output capture will be different compared to the Classic version.
Beta workflow: https://connect.pabbly.com/v2/app/workflow/mapping/IjU3NjYwNTY0MDYzMTA0MzE1MjZjNTUzNzUxM2Ei_pc
classic workflow: https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTY4MDYzNTA0M2M1MjY0NTUzNDUxMzYi_pc
so the issue is if my question type in tally is a multiple choice question, the classic flow will give me only the choice selected by the user while the beta ver captures every single choices but i'm not sure which one is the one chosen by the user.
Hello @worldmasterclass,
Thank you for adding the update.
Since you have resolved this issue on your own, we will close this thread. Please feel free to reach out to us if you encounter any issues in the future.
