Telegram
Status: Open · Asked by mojtapa.alsaalih on · 0 views
mojtapa.alsaalih — Question ·
How do I make a Telegram bot transfer Telegram channel posts to me?
Hi @mojtapa.alsaalih,
You can follow the steps provided in the video below to set up Telegram as your trigger application and fetch channel messages. Only the first part of the video is relevant for you (Ignore the action step).
youtube.com/watch?v=f1dBBA84jBw
You need to elaborate a bit more on what you mean by transferring a Telegram channel message to you, for me to suggest an action application.
mojtapa.alsaalih — Reply ·
Hi [USER=18170] @ ArshilAhmad
I want to transfer other channels' posts to my channel
If you want to post back to your chat on Telegram then I am afraid that wouldn't be possible.
But if you want to send it back to your other Channel of yours then you need to create another bot on your page.
(You may connect your other channel of Telegram to Sync, also ignore the AI part)
youtube.com/watch?v=hlhe_RbUuAM
Thank you very much, but this is not what I am looking for. I think what I want to do is not possible here. I hope to add it in the future.
I regret to inform you that it's not possible to create a dedicated live chatbot in that manner. However, the provided video will demonstrate how to achieve similar functionality through the prompt you provide in the Chat GPT action step.
يؤسفني أن أبلغك أنه ليس من الممكن إنشاء روبوت محادثة مباشر مخصص بهذه الطريقة. ومع ذلك، سيوضح الفيديو المقدم كيفية تحقيق وظائف مماثلة من خلال المطالبة التي تقدمها في خطوة إجراء Chat GPT.
Can you help me with thishttps://forum.pabbly.com/threads/x-twitter-with-telegram.21241/
Initially, we used to have triggers in the Twitter app which will be needed to capture the Twitter data. Recently Twitter has updated its API policy and we will see if we can accommodate supporting triggers as well or not.
So, I am sorry your use case wouldn't be possible.
As of now, the Twitter integration only supports action events only - https://www.pabbly.com/connect/integrations/twitter-2
[IMG alt="1686817737780.png"]https://forum.pabbly.com/attachments/1686817737780-png.27357/[/IMG]
Further, we recommend you post the submission to add the trigger event on the platform here - https://pabbly.hellonext.co/
