Text Split with > char
Status: Open · Asked by phil on · 0 views
phil — Question ·
Just wanted to report that, when using the character >, the Text Split doesn't work properly.
https://punto-rosso.d.pr/FxBrtw
Neeraj Agarwal — Reply ·
@Naveen You should see this. This needs fixing. Thanks @phil for reporting the issue.
I just tested it at my end. It seems to have worked for me though.
@phil Can you test it out once more and confirm that to me?
Also mention the workflow url here so that I can look if it is not working for you.
