The webhook for google sheet does not respond, please help
Status: Closed · Asked by Kaman on · 0 views
Kaman — Question ·
My workflow and google sheet set up has changed nothing but the webhook does not response, no data is being sent to my workflow. When I tried to send test. I received this. However, there is data in row 2 Please help
PabblyMember3 — Reply ·
Please configure the webhook addon on Sheet 1 of your Spreadsheet. That should work out for you.
We are planning to update the addon in the next couple of days which will allow the webhook to be set from any active sheet.
Right now it will work on Sheet 1 of your spreadsheet only.
Kaman — Reply ·
I move the "Hit List" to the most left position. Does it mean sheet 1?
Yes, exactly.
Kaman — Reply ·
Yes, exactly.
It works now. But it needs to recapture the webhook again in order to work properly
