Todoist issue
inochi
Essentially, I've created a workflow with Pabbly, and when I create a task with Todoist, a strange error appears and it doesn't work. I've also tried reconnecting the account and updating the fields, but the same problem persists (see the attached screenshot). How can I resolve this?
Hey @inochi
Could you please attempt entering the description without any line breaks once and then give it another try? It seems like Todoist doesn't support line breaks in the description field, so this adjustment might help resolve the issue.
inochi
Actually, it's not true that Todoist doesn't support any line breaks; I have always created tasks with line breaks. After conducting some tests, I've realized that the problem actually occurs with certain parameters that I pass from PayPal. In this case, it accepts all parameters (such as client email, amount, etc.), but if I include the 'Product' parameter from PayPal into the Todoist task description, that error appears.
Could you perform a thorough check on this?
Hey @inochi
It appears that the character that you are getting from the trigger response is not being accepted by Todoist API. So Can you please confirm the same with the Todoist support team once for the same?
Tried the same at our end -
