Todoist Project or labels
Status: Closed · Asked by Sophieja23 on · 0 views
Hi, is it somehow possible to have the name of the project or label from todoist in google task?
Thanks, Sophie
Hey @Sophieja23
You need to check the possibility of the name of the project from the Todoist application since the trigger is a webhook-based trigger that can only receive the data from the application.
