Trello Add Comment - doing a constant loop. HELP
Status: Closed · Asked by HNguyen on · 0 views
At the end of the workflow that we did, we tried adding a trello comment under the card that we're working on. It successfully added the comment, but it keeps repeating the whole workflow. Any suggestion or fix for this please? Thank you!
ALSO, it keeps doing 10 thousand times. Anything trello doesnt work that well.
Hey @HNguyen
Could you please tell us the Workflow name to check the details?
every single workflow on the BBW - Trello Folder.
Hey @HNguyenCould you please tell us the Workflow name to check the details?
Triggers go off no matter what through Trello:
https://www.loom.com/share/cde67056dbf74d10841f8cef7452d305
Endless Loop once posting to comments:
https://www.loom.com/share/cd221275d60b424bbc022e9f679286ee
Hey @HNguyen
We have replied to your concern on your another thread, so kindly check that out.
