Trello Trigger Issue
Status: Closed · Asked by Teun van der lugt on · 0 views
Teun van der lugt — Question ·
Hello, I would like to e-mail with you so I can CC my tech expert. Can we do that?
We have an issue with a connection that seems to trigger the same automations twice in a row. We need that fixed. Here is a video where we go over it: https://video.sidd.at/conversations/fad1da59-47aa-53f3-acf6-50497b84bab9
Please let's continue talking over e-mail.
Thank you
Pabbly Support — Reply ·
Hello Teun,
Thank you for reaching out.
Based on your description, the issue you're experiencing may be due to multiple clicks on the "Save and Send Test Request" button while configuring the trigger. This can result in multiple trigger subscriptions being created, causing the same event to trigger the workflow more than once.
To resolve this, we recommend the following:
  1. Clone your existing workflow (or create a new one).
  2. Reconfigure the trigger step by establishing a fresh connection.
  3. Click the "Save and Send Test Request" button only once during the setup.
  4. If you need to capture another sample response, please use the "Recapture Webhook Response" button instead of clicking "Save and Send Test Request" again.
After making these changes, please test the workflow and let us know whether the duplicate triggering issue has been resolved.
Also, we have replied to you over Ticket ID - 211178 as well.
If the issue still persists after following the above steps, we'll be happy to investigate it further.
Thanks and Regards,
Customer Success Associate,
Teun van der lugt — Reply ·
Hello, I'm answering this to CC my tech genius. Please reply to ALL next time okay? Thank you.
Tony
Hello Teun,
Tony
Op wo 5 aug 2026 om 12:18 schreef Pabbly Support <support@pabbly.com>:
Hello Teun,
Thanks and Regards,
Teun ‘Tony’ van der Lugt
Founder & Creative Director Golden Era Media
www.goldenera-media.com
Thanks and Regards,
Siddharth Pal — Reply ·
Hi Pabbly Support Team,
We tried already your suggestion but it's not helpful.
Please check the account logs.
I want there should be option in action step to disconnect webhook or something so that it's easier for us to connect or disconnect. Right now it's duplicate event.
If you will check account history, we already setup new workflow to avoid that issue but it's happening.
Please help to fix.
Tony
Hello Teun,
Thanks and Regards,
Hello Tony and Siddharth,
Thank you for sharing the video and the additional details.
We understand that you have already tried the suggested steps and that the duplicate events are still occurring. We’d like to investigate this further by checking the account/workflow logs and understanding the exact webhook behavior in your setup.
To assist you more effectively, let’s connect over a meeting and review the issue together. You can book a convenient time using the link below:
https://calendly.com/d/d3vn-h3q-k3c
During the meeting, we can go through the workflow and account history and determine what is causing the duplicate events.
Please feel free to choose a suitable time, and we’ll take it from there.
Please help to fix.
Tony
Hello Teun,
Thanks and Regards,
Thanks and Regards,
Hello Tony,
Thank you for joining the meeting. I hope your concern was addressed during the discussion.
As mentioned, we would greatly appreciate it if you could share your experience with Pabbly by leaving a review on Trustpilot:
https://www.trustpilot.com/review/www.pabbly.com
Thanks and Regards,
Hi Pabbly connect support team
We are experiencing another issue.
When we move a card from list "A" to list "B" then trigger should happen when it's moving into list "B" only (we already selected the list in trigger step).
But the system is triggering the workflow setup from list "A" too which is dispatching the card.
I tried to understand it by checking the logs but unable to figure it out.
Can you carefully check it so that it will be fixed properly?
This way it is very much complicated.
Please let me know how to fix it.
Please help to fix.
Tony
Hello Teun,
Thanks and Regards,
Thank you for reaching out and explaining the Trello trigger behaviour.
To investigate why the workflow is firing for cards in list A as well as list B, we'd like to review the exact execution details on our end. Could you please share the following:
1. The workflow URL (share link) for the affected workflow.
2. A couple of specific Task History IDs where the workflow triggered for a card moving out of list A (not into list B), so we can trace what payload Trello sent.
Once we have the workflow URL and the relevant Task History IDs, we can inspect the trigger payloads and confirm exactly what is causing the extra runs, then advise on the fix.
Thanks and Regards,
Hi Pabbly Connect support team,
Just writing a follow up email.
Please help.
Siddharth
Please help to fix.
Tony
Hello Teun,
Thanks and Regards,
Hello Siddharth,
Thank you for following up.
We haven't received the workflow URL yet. Could you please share the workflow URL of the affected workflow so that we can check the issue further?
Please help.
Siddharth
Please help to fix.
Tony
Hello Teun,
Thanks and Regards,
Thanks and Regards,
Hello Pabbly,
We need help. Can you reply here?
Thank you
Op ma 31 aug 2026 om 07:51 schreef Siddharth Pal <[email hidden]>:
Please help.
Siddharth
Please help to fix.
Tony
Hello Teun,
Thanks and Regards,
Thank you for the follow-up.
To move this forward and investigate why the workflow is firing for cards in list A as well as list B, we still need the workflow URL (share link) for the affected workflow. Please share that along with a couple of specific Task History IDs where the workflow triggered for a card moving out of list A (not into list B), so we can trace the exact payload Trello sent.
Once we have the workflow URL and the relevant Task History IDs, we can inspect the trigger payloads on our end and confirm what is causing the extra runs, then advise on the fix.
On Aug 31, 2026, 6:14 PM, tony <[email hidden]> wrote:
Hello Pabbly,
Thank you
Please help.
Siddharth
Please help to fix.
Tony
Hello Teun,
Thanks and Regards,
Thanks and Regards,
Hello Ayaaz,
Thank you for reaching out, and I'm sorry for the confusion around the recent plan change.
So we can review your account and assist you accurately, could you please share the registered email address used for the purchase?
Once we have these details, we will review your account and follow up on the best way to resolve this and process the change.
Thanks and Regards,
