Trello Wa Web Plus
Status: Closed · Asked by Brunelly Correia on · 0 views
Hi guys, I'm trying to use Pabbly to connect Trello and WA WE PLUS when a card is moved to a list.
But the trigger request what card I want to move.
Is it possible to put a pattern or a code in that request?
In this way, every card that I move to another list, WA WEB PLUS will send a message.
I don't want to select what card in the field "Card" will be moved.
I need that every card I move from the list "Primeiro Contato" for another, receive a message from WA WEB PLUS.
Is it possible?
Hey @Brunelly Correia
We are currently looking into the Trello possibility of the use case you're requesting for.
Further, would you mind sharing what action events you're looking forward to using for WA WEB PLUS?
I need this data to use in the API as you can see in the image.
In the parameters "phone" I want to use the description on the card.
Example:
In the description on the card I have a client number.
When I moved that card to another list, WA Web Plus will send a message previously set.
Is it possible?
We have contacted Trello, regarding your requirement and we will update you as soon as we get a reply from them.
Regarding this, we have checked your Trello Trigger and it is missing the description field. So kindly re-capture the webhook response with the data in the description field first.
