⭐️ Trick For Hushed ⁿ Pabbly Users ⭐️
Status: Closed · Asked by Илья Малащук on · 0 views
Karek Rami — Question ·
We can use Pabbly to integrate Hushed Numbers With other Apps.
For my use-case i would like to Receive Message/Call Logs from hushed to my Telegram.
HUSHED SLACKPABBLYTELEGRAM
I made Private Slack community for Hushed. Then linked my Hushed account with the Slack channel. Then integrate the Slack With Pabbly connect then you can send your received SMS to what ever app you want like Telegram in my case. and it's worked.
You can also Reply to the SMS using Pabbly by send reply from your app to pabbly then to slack message id and hushed will send the reply as SMS to the sender.
Same thing for Files/attachments you can Link hushed with Dropbox and control your files
(Dropbox►Pabbly►Your APP)
i asked hushed team if they plans to integrate any other apps natively, they said there's no plans to integrate other channels for now. so pabbly here will be best option to Link hushed with other apps. (Also: Hushed in Stack Social Cheaper than Appsumo Deal "25$ on AS and 19$ on SS")
