Trigger for when any task is updated in a project in Asana
Status: Closed · Asked by ahsan on · 0 views
Hi There,
So I see Pabbly Connect has a trigger for a specific task in a project is changed in Asana, however, how can I create a workflow for when for when ANY task is updated in a project? Because it will be impossible to 100s of workflows for 100s of tasks.
Regards
Hey @ahsan
You can use Asana's trigger of "Changed Task" to get the change in tasks which will only get triggered when the change in the "Due at", Due on", "dependencies", " Completed", "assignees" fields from your project tasks.
Though you need to select the specific Project and Task to capture it.
Hey Supreme!
Yeah I have seen this trigger. But my problem is that I donot want to create a bunch of workflows for each task. In Zapier, there is a trigger for "changed task" for any task in a project. But I do not think it is present in Pabbly Connect yet. Is there any chance that this trigger be added anytime soon because I am sure it will be helpful for lots of users.
Hey @ahsan
We are currently working on it and will let you know with an update soon. Your kind patience will be highly appreciated.
Thanks!!
