Trigger Not Auto Triggering
Status: Closed · Asked by zonflip on · 0 views
zonflip — Question ·
I am testing this out on the free plan. I have it set to trigger every 8 hours
But it is not triggering. When I manually load it, the workflow works perfect so I know it's not an issue with the workflow. Please advise
Hi @zonflip,
Please log in to your Google Drive and Pabbly Connect accounts in an Incognito Tab, and establish a new connection with your Google Drive account.
Once you have done that, add a new file to the folder you specified in your trigger step.
Make a screen recording of the entire process and share it here if your workflow doesn't execute within 8 hours of adding file to the specified folder.
zonflip — Reply ·
This worked, thank you.
