Trigger Not Firing - Workflow Stuck
Status: Closed · Asked by realestatebroker on · 0 views
Hey @realestatebroker
Please elaborate briefly on your concern and where exactly you are getting stuck so we can look into it.
I am sending a webhook thru Gohighlevel. When I test it works fine. But when I do live it is not performing the workflow.
I have also confirmed the webhook has been sent, but pabbly is not doing the workflow
You can check it through a webbooks testing site called webhook.site. Kindly note that the Webhook By Pabbly trigger event is a webhook-based trigger event that only gets the response once sent by the application.
You can copy the webhook URL provided by Webhook.site inside your application and do the test event inside the application to see if the webhook response is being delivered inside Webhook.site or not. This will double-confirm the issue.
Here is a sample video that you can follow to track the webhook issue:
https://webhook.site/#!/be4085b1-079e-403c-b2b8-0084317bb4ec
they did not fire last month, and this month they alll fired at the same time (today) and exhausted all my tasks
Could you kindly enumerate the workflows in which you have encountered this particular issue?
