Trouble connecting to OneNote
Status: Closed · Asked by Henny on · 0 views
Henny — Question ·
Hello, I'm setting up a workflow that connects a Google Worksheet to OneNote.
However, when I select 'Add New Connection' and then click the button 'Connect With OneNote', only a square (existing from 9 little squares) appears for a brief moment. But then nothing happens.
When I click 'SAVE' a get a warning 'Please Authorize this App'.
How do I connect to OneNote, how do I Authorize this app?
PS I am testing things here on a free account, might that be the issue?
Hey @Henny
We have tested the "OneNote: Create Html Note" at our end and it is connecting properly. Kindly clear your browser's cache memory and then try again. Else you can try to connect the action step in the Incognito Mode of your Browser.
Though we have recorded a short video on how it is connecting. Kindly check that out and let us know if that works for you.
https://www.screenpresso.com/cloud/0nOsc/
