Mathilde
I want to use Pabbly to add Contacts to a Notion Database (and a Mailerlite group, but this part is working), or update the contact details if it already exists.
The trouble is how to correctly filter that...
I've tried different ways but they don't work : with a Query, it seems that my filters don't work, I've got an error even if I checked the syntax...
I've found a post with a similar problem but I don't find the "search date base item" action for Notion, like I saw it that post so...
I just want to check if the mail of my person exists in the database, and update or create the database item, depending on that.
Can anyone help ?
Thank you
Can anyone help ?
Thank you
