Twilio API body setup
Status: Open · Asked by tsuiwilliam on · 0 views
Keep getting this error: https://www.twilio.com/docs/errors/20001
Looking to use pabbly to trigger Twilio Studio Flow
Hi @tsuiwilliam,
Please try entering your Twilio phone number and check whether this fixes the issue for you.
If this doesn't fix your issue, please share the Twilio API documentation and the endpoint you are trying to execute.
yah same error, this is their documentation, couldn't figure it out even with gpt lol ?
https://www.twilio.com/docs/studio/widget-library/trigger-start
thanks for the help!
It seems you've fixed the issue since you are no longer getting the error.
