Twilio automations with HighLevel?
Status: Closed · Asked by greenfox on · 0 views
I have a Twilio phone number configured through HighLevel, and HighLevel currently uses the webhook slots for incoming Calls/SMS.
All I want to do is import completed calls into a pipeline in HighLevel but traditionally this was done no problem with Zapier's integration.
Because of the way Pabbly uses webhooks for most automations...does this mean I can't use Pabbly to send completed calls into HighLevel?
Hey @greenfox
We looked into your concern and it is like you can capture the webhook response of the call completed by a user from your Twilio Trigger. But GoHighlelevel doesn't provide any action event from their API to send the data/record the completed call into the account.
Further, if you found any documentation to record the call data in GHL let us know.
Thanks!
