Twillio SMS body felid not writeable?
Status: Closed · Asked by Brendan Bunting (#Brendo) on · 0 views
Brendo — Reply ·
Found the issue. Its a form bug. the feild requires you to select a feild from the dropdown then delete it to gain keyboard access to the pace.
Hey @Brendo
We looked into your concern and perhaps due to your browser's cache memory you. You might not be able to type/map on the field.
Else, we have checked the same and it is working fine.
