Typeform Dynamic Mapping Issue
Status: Open · Asked by Jake Efstration on · 0 views
With the Typeform integration I have an issue with the way the data is mapped. We have questions that show dynamically based on the answers of previous questions. The issue is that these questions don't show in the response data if they are not triggered by the question, but if it is triggered by the correct answer in a previous question, it does show in the response data - when the question does show it throws off the order and the fields then map incorrectly. Is there a way to parse this data so that the order of the data is irrelevant?
Hi @Jake33,
I'm afraid the use case you are describing is not possible because the mapping will always break if proper responses are not coming from the trigger step.
As a workaround, you can try capturing all the responses by giving the correct answers to all the questions, and then mapping all the relevant data to another application. However, even in this case, the application to which the data is being mapped should accept empty responses; otherwise, this will not work.
