Unable to Connect Smartsheet Integration - 1004 Not Authorised
Status: Closed · Asked by Adam Prettyjohns on · 0 views
Hi All,
I'm trying to connect my Smartsheet (Business) account to Pabbly Connect, but each time, I am returned a 1004 error every time.
I have created a new API key, and edited the SS Connection in Pabbly, so I'm pretty sure that's good to go. The connection to the account appears to be successful, but I cannot get past the 1004 Response Error Code, whenever I hit Save and Send Test Request.
I wonder if anyone had any ideas?
Thanks!
Adam
Hi @adampj,
Please establish a new connection with your Smartsheet account by following the steps provided in the help text. Be sure to add the word 'Bearer' as a prefix when entering the API Token.
Hello @ArshilAhmad,
Thank you so much for your swift response. This was a great help - the worded 'Bearer ' was important to include, and was not included in my original configuration.
Having created a new connection, and added Bearer , this has resolved the issue. Bearer is not mentioned in the UI of Smartsheet, so it's a key step I didn't see in the instructions.
Thank you so much - fantastic help!
Adam.
Hey @adampj
Thank you for the update I hope the assistance provided was helpful to you.
