Unable to connect unbounce with convertkit
I tried connecting Unbounce with Convertkit using Pabbly today.
Unbounce is working fine, but Pabbly can't work it out with Converkit. It's throwing errors.
Context: I'm trying to add subscribers to a form in convertkit. Form is created, automation and sequence are also setup, but Pabbly is not performing the action.
Supreme
Hey @Hit Office
We looked into your workflow and due to double quotes, closed square brackets the error is processing.
So to eradicate the error you need to capture the webhook response in a simple response that might not include the square brackets and quotes. Then re-map the respective fields.
Kindly try again and let us know if that works for you.
