Unable to create Harvest project
Status: Closed · Asked by Jon Baker on · 0 views
I'm new to Pabbly and trying to migrate from Zapier. I set up a workflow that should create a Harvest project when a Jira epic is created. I've successfully pulled in the sample trigger from Jira, but the Harvest implementation is failing with the message "Name Please enter a project name., Client Please enter a client." I have the client ID that I got from the Harvest API call to "https://api.harvestapp.com/api/v2/clients.json", and I am using a field from the Epic for the project name, yet I am getting this error message. Even if I explicitly enter a project name (without referencing fields from the trigger) I'm getting the same response ... any ideas on what I'm doing wrong?
Hey @jdavidbakr
Could you please share the name of the workflow along with your registered email address with the complete use case, so that we can look into it and can guide you accordingly?
Hey @jdavidbakrCould you please share the name of the workflow along with the complete use case, so that we can look into it and can guide you accordingly?
Sure - it is "Tag TPLC on release"
Basically in Harvest I am creating one project per Jira epic, so I've been creating the project in Harvest after creating the epic in Jira.
I'm planning to have one workflow for each Jira project - so the Jira webhook has a filter that sends a single project epic creation to the webhook; this part I have successfully done. The action should then create a new Harvest project. The project name will be the Jira epic summary name, and the client ID will be hard-coded in the workflow.
Let me know if you need any additional clarity. Thank you for looking into it!
Thanks for your reply, kindly also share your registered email address with Pabbly in which your workflow exists.
I sent my email via a private message.
Hey @jdavidbakr
We have replied to your query on your another thread, please check that out.
