Update Active Campaign does not work
Status: Open · Asked by info@via-internet.de on · 0 views
i created a workflow to update a active campaign customer.
The workflow is triggered by Zylvie.
I want to update the active campaign tag of the customer.
When using a Tag from a list (No Map, and use Tag from Dropdown List) everything is working
But when use a Tag from the Zylvie Response (Field Data Products 0 Title) the Tag is not added.
The Tag exists in active campaign
When running Save & Test Request i get the errors:
Res5 Errors 0 Title: Ungültiger Wert für Abfrageparameter contactTag.tag
Res5 Errors 0 Detail: No tag id provided
Hi @r14r,
https://connect.pabbly.com/workflow/mapping/IjU3NjYwNTZjMDYzMjA0MzE1MjZlNTUzZDUxMzYi_pc
ActiveCampaign requires you to pass the Tag ID associated with a tag, not its name. We have added a "Search Tag" action step to your workflow to fetch the Tag ID associated with a particular tag name and mapped that Tag ID to the "Add a Tag to Contact" action step. This seems to have resolved the issue you were encountering.
