Update airtable using open ai
Status: Closed · Asked by dopeghostseo on · 0 views
dopeghostseo — Question ·
I managed to create a workflow that updates airtable, the problem is that it only updates the last record created, I need it to update all the records in a column base on the prompt that is in the prompt column, prompt column to open ai, open ai returns description to the description column.
Hey @dopeghostseo
Kindly share your workflow once where you have established the action step according to your need so that we can look into it.
