Updating product variations on Woocommerce - Pabbly Connect
Status: Closed · Asked by cheetaweb on · 0 views
cheetaweb — Question ·
There seems to be no way to update product variations via the Woocommerce app on Pabbly
The Woocommerce REST API requires two post ID's to update a variation, the one for the product and the one for the variation. The Update Product app only allows me to input a product ID even if I choose product type of variation.
Any idea if there update variation hook is implemented somewhere?
Hey @cheetaweb
As of now, it is not possible. We have shared this requirement to the integration team and hopefully it should be available in next WooCommerce integration update/
You will be notified about this once its available.
Hey @cheetaweb
We have added a new action event " WooCommerce: Update Product Variation" as per your requirement, kindly give it a try and let us know how it works for you.
