Urgent - Need help with Uteach Integration with Pabbly.
Status: Closed · Asked by Poorna Potluri on · 0 views
I am only seeing API keys in the Uteach Integration settings section, I even contacted the support team only to hear "we are considering a video tutorial". Any help from team is much appreciated
The Utech integration is still under review and it will be published soon. We will keep you posted once the integration is made live.
Uteach integration is live - https://www.pabbly.com/connect/integrations/uteach
Please login to your account and check at your end.
