Urgent Request Pulsetic Connection
Status: Closed · Asked by Yanuar on · 0 views
yanuar — Question ·
Can you add Pulsetic connection to Pabbly? I ieed it ASAP, thank you
Deleted member 9923 — Reply ·
Hello @yanuar ,
You can explore the different integrations you can create with Pulsetic application & Pabbly Connect using the following link:
https://www.pabbly.com/connect/integrations/pulsetic/
If you have any further questions or need assistance, please let us know!
yanuar — Reply ·
Thank you for your response. Can you add trigger events like Uptime Robot?
  • Up & Down Events
  • Only Down Events
  • Only Up Events
Hello @yanuar ,
If you want to request for update on any existing integrations with triggers or actions, please send us the request here.
https://pabbly.hellonext.co/b/Update-Existing-Application
Our team will review the request and possibly add the integration soon if possible if there team offer webhooks for creating those triggers.
