Using Connect with Heartbeat app for scheduled postings
Status: Closed · Asked by Bizforge Staff on · 0 views
Hello, we did a search and couldn't find a specific tutorial for our use case. We want to create scheduled posts from a Google sheet to Heartbeat.chat app.
The selected action in step two is create thread in specified channel. But what are the steps needed before that to check google sheet and post content for a specific day? What trigger should be selected?
If there is a video that detailed that first step please send the link.
Hey @Bizforge
You can refer to the following video tutorial for a similar use case.
We are working through it now. Which of the different available commands of the Pabbly connect Webhook (after clicking the extension tab) should we use in the Google sheet to be triggered for a scheduled thread. The spreadsheet will just have the basic fields of date, post, poster.
Hey @Bizforge
Can you please share your concern in detail, about where in your workflow you are getting stuck so that we can look into it and guide you accordingly?
