Using Pabbly Connect to Integrate ThriveCart and Shopify
Status: Closed · Asked by StrikingViper on · 0 views
As the title suggests, I'm trying to use Pabbly Connect to integrate my ThriveCart and Shopify accounts.
In Pabbly, I notive the ThriveCart integration has options for:
- Orders
- Bumps
- Upsells
Does "Order" cover everything in a customer order including bumps and upsells, or does it only cover the main product for the page?
If I have a bump and an upsell, do I need to setup separate workflows for each bump and upsell?
Hi @StrikingViper,
Order (Product Purchase) does not trigger on Bumps and Upsells. You need to create separate workflows for this use case.
Thank you.
Let's say I have:
- A thrivecart order form for Product A
- Product B as the bump on that form
- Product C as the upsell
I have three seperate workflows, on for each product, sending that data into Shopify.
Does this mean that the customer will have three separate orders inside Shopify?
If I have a second checkout, with different products on it, do I need workflows for each of those too?
Yes, the customers will have 3 separate orders inside Shopify.
No, the same workflow will be triggered on second checkout as well.
Does this mean that if I have Product A on Checkout 1, and Product B on checkout 2, my workflow will only create an order in Shopify for Product A, even if Checkout 2 is completed?
Please record a short screen recording elaborating on your exact concern. Additionally, try setting up the workflow and testing the scenarios on your end.
I had a play around and I understand what I need to do now, thanks for your help
Thank you for the update. Glad you were able to find a solution.
