Using Pabbly filter to filter product name but it is not working properly
Status: Closed · Asked by Raghav Gakhar on · 0 views
Hey @RaghavGakhar
We have made some changes from our end and it should work accordingly now. So, you can try executing the tasks again.
RaghavGakhar — Reply ·
Hi, I checked the workflow and couldn't find changes, can you tell me what you have changed. I will learn something new here. thanks.
Hi, it is still not working. Check -
Task History ID -
IjU3NjAwNTZiMDYzNjA0MzU1MjZkNTUzMDUxM2I1MTY1NTQzNCI_3D_pc
Please manually type the name in the value field because it seems like you might have copy paste the name in the fields which could have contains a div hidden.
So, please try passing the names manually.
I have now typed the names and passed them. I hope it should not work. I will ping you again tomorrow if it is not working.
I was thinking, should we do. "contains" instead of "equal to"?
Yes, you can use the "Contains" filter type in the Filter action step to perform the same task.
