Using Pabbly to Update Custom Fields in Suitedash
Status: Open · Asked by 321Action on · 0 views
321Action — Question ·
Pabbly has modules developed that will Create or Update a contact in Suitedash but then I need to do the next step and run an automation from within SuiteDash. The only trigger that Suitedash has is when the status of a Custom Field changes. HOW can I update a Custom Field for a contact in Suitedash? Can the Custom API Call do this?
Hello @321Action
We have forwarded your concern to our technical team, and they're looking into it. If possible, they will add the custom fields to fulfill your requirement. Please allow us some time, and we will get back to you with updates as soon as we have them.
321Action — Reply ·
That would be Great! Thank You!
Hello @321Action
As per the conversation with the SuiteDash team, for the required action the endpoint will be updated with their next API Documentation release, refer to the attached image for more info. As we hear anything from their end we will let you know.
Moreno — Reply ·
Hello @Preeti Paryani
Any news about this? I'm not running automations because this is missing from your hand, SuiteDash has already updated the API.
Same issue with NinjaPipe, custom fields are missing
Could you please specify the action event to which you want the custom fields to be added?
Moreno — Reply ·
create/update/get contact.
Thank you!
Hello @Moreno,
Thank you for sharing the details.
We just wanted to inform you that we have not yet received any update from the SuiteDash team regarding this concern. Our team is currently reaching out to them again to request the updated documentation.
As soon as we receive any information from their end, we will promptly update you.
Thank you for your patience.
Hello @Moreno,
We just wanted to inform you that we have not yet received any update from the SuiteDash team regarding this concern after certain follow-ups. We recommend reaching out to them with your concern, as it may help expedite the process.
