Using Pabbly with Clickup
Status: Open · Asked by Michelle D. Smith on · 0 views
I would like to be able to update a Task in ClickUp based on an event in another program or from an email to me. I cannot figure out how to either map the fields or find them in Pabbly COnnect. Can someone help me figure this out?
TY!
Hi @mishmith,
If the other program you are referring to supports webhooks, you can try using Webhook by Pabbly as your trigger step to capture data from that program.
youtube.com/watch?v=FRkl5R7-Ls0
If you want to capture the details from your email, you can try setting up Email Parser as your trigger step to fetch the details from the emails you receive.
youtube.com/watch?v=GL4GDONwSdE:360
You can try using the 'Update Task' action event to update your ClickUp task
