using Text parser
Status: Closed · Asked by HamiltonFirePaging on · 0 views
HamiltonFirePaging — Question ·
Task History ID: IjU3NjIwNTY1MDYzMjA0MzQ1MjZiNTUzNDUxM2E1MTY2NTQzMSI_3D_pc
Using Text Parser is there a way to give a value if the Text Match doesn't exist? In my case the message being sent doesn't always have a field in the string. When this happens, the whole string is provided instead of none of the string.
Certainly! If the value you've mapped doesn't come through in the automation, you can utilize the Text Formatter: Default Value action step. This allows you to set up default values to ensure a smooth process. Give it a try!
youtube.com/watch?v=oFvzL6iaDAI:1115
