Waiting for response forever
Status: Open · Asked by Garral on · 0 views
Garral — Question ·
Hi. Usually, whenever I execute a test request or a webhook response, the application keeps "thinking" indefinitely (it has happened to me with all the applications I have used so far: Google Sheets, Typeform and Gmail).
I have consulted about this error before and was able to fix it with your help, using a Chrome incognito window, but I find it very annoying to have to do this every time I use Pabbly Connect.
I am looking forward to buying a license, but this problem is holding me back.
Is there not a more operational way to solve this problem in a definitive way? Thanks!
Pabbly13 — Reply ·
Hey @Garral !
We are sorry for the inconvenience you have gone through.
The issue arises because of the Cache in the browser, which needs to be clear-out in order for smooth functioning of Pabbly Connect.
If you are not comfortable with the using of Pabbly Connect in Incognito mode, then when setting up any new automation in your workflow you can simply just press "Control+R" and it will erase your cache and then you won't be getting any error afterwards.
Hope, this workaround works for you.
Best Regards.
Garral — Reply ·
Ok, thanks
Garral — Reply ·
Well, I don't know what to do anymore. I am about to leave. The problem continues to occur and it is exasperating, a huge waste of time. Sometimes it works, but most of the time it doesn't.
No matter if you try in incognito mode or press Ctrl + R, the application keeps waiting for a response constantly.
There must be a way to fix this. If not, it's useless to me
Neeraj Agarwal — Reply ·
Can you please supply us with a video of the issue that you are experiencing?
seminare_sk — Reply ·
I have the same problem each time I change something in pabbly within a workflow. Chrome incognito doesn't help at all.
Pabbly — Reply ·
Can you share a small screen recording of how exactly you're doing the workflow set up at your end?
Further do check the video tutorials as well that will help you understand how the workflow are actually being setup - https://www.youtube.com/channel/UCVA5GKy8qpDxQR5xSt_zcJg
