webhook connection problem with google spread sheet
Status: Closed · Asked by Thesyndicateanalytics on · 0 views
I have an issue with connecting the pabbly with google spreadsheet by using the webhook. when I try to trigger the instant connection it shows only "waiting for webhook response"
Hey @Syndicate space
Kindly refer to the following video tutorial on how you can capture the webhook response.
(Watch the first part of the video)
When I am trying to connect with the Google sheet and the UChat, at that time webhook is not connected. it takes too much time for loading and it shows only "waiting for webhook connection".
kindly do the needful for me.
Kindly turn off then turn on the workflow once and then try again.
E.g. -
E.g. -
