Webhook Cors problem
Status: Closed · Asked by Fanny Opti-Biz on · 0 views
opti-biz — Question ·
I am sending data to Pabbly webhook via a javascript; it used to work correctly at least until 17/03/2025, but then it stopped working, throwing CORS error.
Can you please check this ?
opti-biz — Reply ·
I have contacted the app provider from where the data is sent, and they informed me about this:
I've checked the headers, we don't have for example: "Content-Security-Policy: connect-src 'self'" or anything similar, which could block that, so you can mention that.
Hi @opti-biz,
We couldn't find any errors in the workflow you shared. Could you please elaborate a bit more on the exact issue you're encountering, and also specify where exactly you're facing this issue?
opti-biz — Reply ·
The workflow does not have any issue; the problem is that data sent towards Pabbly was not going through (it was working already for several months, then stopped working since March, 17th).
However, I retested this morning to provide you with screenshots, and now it works again; have you updated anything ?
Hello @opti-biz,
Yes, our team has made some changes, and it appears that the issue has now been resolved.
