Webhook is not passing data to next step
Status: Closed · Asked by Sagar Mondal on · 0 views
sagar_mondal — Question ·
Recently I'm facing a weird but very serious issue with my workflow. I'm using this workflow to automate my HTML form submissions (using webhook) with Google Sheets. And I tested it after deployment & it worked fine.
But recently one user submitted the form and we got a blank value in the Google sheet. After checking the task history, we found that although pabbly had captured the webhook response but didn't pass it to the next steps. This is really concerning as we may miss leads like this in the future which will affect our business.
Hey @sagar0307
Kindly share the name of the workflow in which you are performing such a task and the task hisotyr Id in which you have seen such a pattern.
