Webhook response for Kartra is doesn't work
Status: Closed · Asked by jirathknot on · 0 views
I try to follow instructions from this video
youtube.com/watch?v=E95Z6EsUs5g
but webhook response is doesn't work it's still waiting for response for a while. how can I do ?
Hey @jirathknot
As we can see from your workflow, you have already captured the webhook response correctly. Please check your workflow again and let us know if you have any other issues.
Hey @jirathknotAs we can see from your workflow, you have already captured the webhook response correctly. Please check your workflow again and let us know if you have any other issues.
Yep It's captured data correctly but when I try to input form in katra It's seem this workflow doesn't work. lead data doesn't auto create a new row in target sheet.
Hey @jirathknot
As we have again looked into your workflow, you made some changes and your webhook response is not present on it. To make your automation work you have to capture the webhook response correctly and map the response data to the Google Sheets Add New Row as mentioned in the video tutorial.
