Webhook Response Module Missing After Upgrade
Status: Closed · Asked by Heikparaguay on · 0 views
Your Workflow URL: https://connect.pabbly.com/v2/app/workflow/mapping/IjU3NjcwNTZmMDYzMTA0MzY1MjY1NTUzNDUxMzQi_pc
Hello, I just upgraded my account to a paid plan, but the "Webhook Response" module is not appearing in my workflow (neither in the New Beta nor in the Classic builder).
I am using a "Webhook by Pabbly" as a trigger and I have already captured test data, but when I search for "Response" in the action steps, it doesn't show up.
Can you please check if my account permissions are correctly updated? My account email is: [email hidden]
Hi @Heik Rosa,
Please try using Slash (/) for mapping the data in New UI. The response from the trigger step will appear.
Arshil Ahmad
?Rate your support
