Webhook to Highlevel not executing steps/actions - Urgent
Status: Closed · Asked by raynimator on · 0 views
Hello, we have created webhook that catches the data package, but it doesn't do any actions, it doesn't show in the history too.
When we click to TEST it creates the contact, but when sending to webhook, it doesn't do anything.
I was hesitate about upgrading to full year, because I need it to work and I am coming from zapier with 2000 task limit,
so please show me if this works, as my contacts coming in and I will have to stay with zapier as pabbly at this moment doesn't work.
since you have created a webhook to capture data and put that data to some place ... so unless you define the second step or action it will not show up in history
~ AUTOMATION EXPERT
~ QUALITY SERVICE
~ ENTREPRENEUR
~ TECH INQUISITIVE
Sorry but this doesn't solve the problem for us, the actions are not doing anything, it is NOT passing the data to the Gohighlevel
Hey @raynimator
We checked two workflows from your account and one workflow(Properties for sale MAIN May 15) is working fine as it is taking data from the API correctly and passing it to GHL.
Where on your other workflow(Villas for sale MAY 15), you kindly configure your webhook URL again in your trigger API and then try again.
